Just to be clear on the capability of the dual Snap Amp with Kanalog on the K flop. I need to do th following:
close the position loop on 6 Snap Amp axes
close the position loop on 2 axes running on the Kanalog
set the output values on 2 open loop analog outputs ( no PID)
read 2 analog inputs
Will any of this impact digital I/O on the Snap Amps?
Would I still be able to use the unused (not assigned to an axis) encoder inputs on the Kanalog or the Snap Amps for other open loop encoder counting?
AZ
